172 cup headlight help
Car  Cup Turbo, Flamer
I'm after removing my passenger side headlight so i can feed my cold air pipe up from the fog light. I've undone the bolt on the top to release it but still doesnt want to budge!
Are there any other bolts/clips that need to be taken off before it will come out?
Cheers in advance
take passenger side front wheel orr , the arch liner, remove the acoustic valve then run it down that way
It's actually really quite easy. just pull the wheel arch liner out, undo one screw and a clip then the bumper will just pull off enogh to get to the lower two bolts holding the light in place.
