172 Cup Misfiring - Interesting Problem
  RS Clio 172 Cup
Hi guys, I've recently been having some misfiring issues with my 172 Cup, probably just down to the coil pack or HT leads, of which both I have ordered replacements of. The problem is that I am a student and have just moved back to uni for 2 months, leaving my car at home, before I had time to fix it. So the question is should I get someone at home to drive it every now and then (as I would usually do to save it from standing still for 2 months), or should I not drive it for risk of damaging something? Is it actually doing my car any harm running on 3 cylinders?
While I'm asking, is there anything else that could be causing the misfire? They're new sparks, and I'm going to do the TDC sensor as well, anything else it could be (apart form injectors)?
If it's running on 3 it's unlikely to be coil pack as it's a wasted spark setup. I've seen two with a duff injector in as many weeks so worth measuring the resistance of the injectors to check they all match and one doesnt have a duff coil.
  RS Clio 172 Cup
Ok thanks, I will try measuring the coils and see if one is faulty. But in the mean time should it be driven do you think? What are the risks?
  Clio16v/225 Trophy
As above, check the electrical "Health" of the injectors. Also check that the connection hasn't broken off as they're a poor design TBH and easily damaged resulting in misfire like symptoms.
