172 engine in 1.2 dynamique
you really do need to use the search button, but yes you can drop one in it. K-tec do conversions
looking at about £1500 for everything needed, Matt does conversion kits with everything needed.
most places would charge around £1500ish for labour so your looking at £3000 to do it.
only way i would do it is if like me you could do it yourself and save labour then its a cheap power gain!
i cant get the engine from a rit off (rear) clio 172 for 600 quid so it should be at bit chaeaper and the engines perfect.
