172 Mk2 Ph1 ABS Pump Location
Car  Clio 172 Ph1
ABS faulty. All cables, rings ok as checked by specialist. Suspected pump
2 options are:
1) To replace with non ABS Cup brakes
2) Replace faulty pump
re option 2. I can see that the brake fluid reservoir is on left hand side bulkhead, is the pump behind there as well ?
how easy to get to remove / refit etc ?
