172 or 182 manifold....Forged engine + ITB's
Barron
Car  Turbo S,Exige,R5,182
According to myth....
172 - Better for top end
182 - Better for mid-range
How reliable is this?
Looking at either manifold for a full forged itb'd engine with very peaky cams (should peak at 7800-8000rpm)
which would you go for? why?
Personally im thinking 182 manifold but would like some other opinions.
Carl
I'll be running a 172 on mine. Identical engine spec from what it sounds.
172 manifold all the way
If your budget can stretch to it... Ceramic coat the manifold while its off the car?! :)
Carl
Isn't that purely to so with the exhaust system and final drive?
Presume you're talking about exhaust Mani?
A 4-1 is generally more suited to a high revving engine which is why they are generally used on motorcycles.
A 4-2-1 will marginally increased low end power
The difference is there but very subtle. I thought it pulled better mid and top end in my experience
Worth it if you can get it all done cheap. Very handy for cat messing too
