172 turinis on my 182 scrubbing issues.
Car  Honda ATR
hi folks got a set of turinis on my 182. I belive they are for a 172. but they are scrubbing like a SOB, my motor is pretty low. Is this more of a ride height issue or is the offset different on the 172 turinis.
If yours is low then yes the cup turinis will scrub lik a mo fo. They have a smaller offset so give it a wider track.
cheers mate, think ill just take the ride height up again. do you know whats the lowest height you can run without scrubbing? ie 30mm
I have the 16" Turini's on my 172 and am lowered 30mm and I do get some rubbing on the NSF, which is sooo annoying as it doesn't seem to happen on the OSF. So that may not be down to it being too low and the wheels sitting further out, but more of a suspension issue on my side.
Ive got a 172ff with 172 cup turinis lowered on coilovers. I have 205 tyres as well fitted, front on the 172 seems fine but mine rubbed like hell on the back I have really had to crank the coilovers up at the rear
so please, could you answer this question "do you know whats the lowest height you can run without scrubbing? ie 30m'' ? car 182FF. Im looking to buy a ktec collies and I have to know this.
Thanks.
