172cup electric window stuck open HELP
Car  172 ph1 Altea FR 170
Evening all.
I am having the common problem with my drivers side electric window on my 2003 Clio sport 172 cup.
It is currently stuck open... i have had this problem before and managed to get it up using a trick that someone had posted on here by removing and replacing the fuse for the central locking which worked a treat! i then went on to get an auto electrician to have a look over at the issue and thought i had it fixed but on the way to work this evening it would not close up again and the 'fuse trick' will not work for some reason!?
Hoping that some one can help as i don't fancy leaving it parked up with just a black bag for security!!! :S
Thanks for the reply.
The window randomly went up on it's own this morning!
It was only making a click noise from under the glovebox when you preseds the switch to open window but nothing when you tried to put it up.
Today now what i think is the relay for the windows under the glovebox has been going mental...randomly clicking all over the place as if i'm operating the swithces.
Originally the auto electrician diagnosed the problem to be a gromet not in place properly allowing water to run to the black box under the glovebox and making the electric windows play up...i still think this is the case but haven't had the time to properly see. Will post on here how i get on.
