Evening all.
I am having the common problem with my drivers side electric window on my 2003 Clio sport 172 cup.
It is currently stuck open... i have had this problem before and managed to get it up using a trick that someone had posted on here by removing and replacing the fuse for the central locking which worked a treat! i then went on to get an auto electrician to have a look over at the issue and thought i had it fixed but on the way to work this evening it would not close up again and the 'fuse trick' will not work for some reason!?
Hoping that some one can help as i don't fancy leaving it parked up with just a black bag for security!!! :S
