182 camber front
Car  clio 182 sport cup
Right im on soax coilovers etc solid top mounts etc and the car is spirited driving track car.im looking to run a couple of degrees camber with camber bolts(already have these).the car is currently running 5mm front spacers.will i have to go to a thicker spacer to get a couple ofdegrees camber?and im assuming longer wheel studs.any advive very welcome thank you
depends what offset wheel your running (and the tyre size). Im my experience you can get away with plenty of camber that is offered through camber bolts without any drawbacks - without fouling strut etc. But its not an exact science. If you've swapped wheels/tyres etc its generally a suck-it-and-see scenario. My experience is with standard struts by the way, not spax
