182 dodgy (abs?) wiring
Car  182
Right got a problem here, on the dash i get SERV, ESP, ABS all lit up intermittently, sometimes it will stay up for a bit, other times it wont come up till 20 mins into a drive. Took it down a reno specialist this morning and he checked some fault codes and came up with rear right wheel abs sensor broken, he also looked under the car where there is a bit of wiring that you can sort of play with and the dash lights go out for a few seconds and then come back on with more play! He said i can redo the wiring and for about £100 as that would prob be the first port of call oppose to the sensor, what do you reckon on that price/advice? Its also a bit crazy because it might actually be the sensor in the wheel and i dont wanna pay out if the wiring doesnt need doing.
Hope that all makes sense.
Any help is much appreciated.
