200/220 brake nut/bolt torques
Car  220 Trophy
I am soon replacing the discs & pads F&R on my 220 and can’t find anything as to what all the torque settings should be.
As far as I am aware:
Fronts:
Calliper bolts
Disc to hub bolts
Rear:
Calliper bolts
Disc to axle bolt
Are there any others I've missed and does anyone know what all the relevant torques should be please?
Rear discs hub nut will no doubt be 175nm like most Renault Sports.
Front disc retaining screws will just be nipped/20nm.
Not sure on caliper bolts, depending on their size it could be 100nm or just FT (fuckin tight).
I spoke with Renault in the end and good job I did because the rear disc-hub nut needs to be tightened to 220NM (not 175NM!)
The calliper-carrier bolts F&R are 80NM
And the caliper-caliper bolts F&R are 20-25NM (no definitive setting)
Plus wheels 130NM
