Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Yes, it will fit. Its a very popular conversion - loads of people on here have done it. You can run it with the 16v gbox (many people do), although someone else will fill you in on this Im sure. You will probably need a new chip as well.
you can use the megane bottom end with all other 1.8 parts except for starter motor. this needs to come off the 2l bottom end. All you will need to run it is a chip, £150 from Hill Power. i have one for sale in the for sale forum(bottom end)
Thanks for all the info! I feel a bit alone upp here in Norway with my clios. I think the total of 16vs are 4-5 in the whole country So you fellas whith the steeringwheel on the wrong side are a great scource of info..
So if I understand it right: I buy an 2.0 16v Megane engine. I put on my gearbox, whith the exhaust from the clio. Put on the starter from the Megane, and chip the ECU with the Stage 1 willy chip (or2??) from Hill Power?
