ABS Light on after changing hubs.
Car  Seat Ibiza
Ok, so recently changed the wheel bearings on my 1.2 Ph2,(Both sides but only 1 actually needed doing) and now the ABS light and Service light is on, when the ignition is turned on, it does go out and sometimes will go 1/4-1/2 a mile without turning on but then will be on for the rest of the journey, need some advise?!!? please, Thanks!!
I can't tell if you mean front or rear? What parts have you changed? Genuine?
ABS wheel speed sensor has been knocked adjusted whatever, get the code reset and see if it goes away, if not it could be the abs rings on the hubs
