ABS Ring Change Out
t90_lle
East of England
I’m going to be doing an abs ring change out on the BG. Is it literally 30mm drive shaft nut off, 2x lower arm bolts, knock shaft out of hub, remove and refit abs ring and refit back together? Is there anything I should be mindful/careful of when doing it as it’s the 1st time in trying one.
