Abs
i thought of that, but i'm reluctant. when i put it back in will it extinguish the warning lamp or have reno (like so many others these days) programmed it so you have to take it to them and get the fault cleared before the lamp will go out
I would replace it with a blown fuse.
If the worst should happen and you were in a serious accident and they found the fuse was removed you would have void insurance...
Watch out...
Without ABS, you could be running 50 / 50 % bias front/rear... it should be 90 /10 %
Check to be sure, to be sure.
