ABS
Front or rears Giles?. In a nutshell undo the bolt holding them on, usually T30s/10mm bolt and take them out. They will be tight if they've never come out before, bect to soak them in penetrating oil the day before helps. Just unclip it the other end aswell where the loom joins.
here...
ABS moving around but it holding on the silver bit, how it come out??
it off from 172 btw
why do you need to take them off?
cos other rear axle was f**k so I have to take it back and they got other one to replace it but this one from 172 cup 03 19k miles it done but there no ABS....WTF:S so I have to take the ABS & the black bits off but I need to take the ABS out put in the new one.
does 172 cup have ABS??
no cups dont come with ABS. surely there wont be a hole in the metal surround shown in the pictures for the ABS sensors to go from the cup
cup got holes same the standard 172
if I can't get the ABS out then I have to try get the hub out
if they are the same then can you not just swap the hole lot over then rather than jsut the sensors? are the ABS rings attatched to the discs or are they seperate?
the hubs are hard to come off & looks like it stuck tbh:dapprove:
dunno about the disc you mean??
where is edde!! lol
