Alloy Boot mounted tank.
billinjah
Car  Ph2 172
I’m fitting a fuel tank in the back inside. Just wondered if anyone else had done this and which fuel pump you used 172 ph2 as I assume the oem pump is pressure sensing? Did you use a swirl pot? Many thanks for any help.
