Alternator question
  ITB'd 172 POPTART
  ITB'd 172 POPTART
Thanks for the reply.
If i can add to this post the problem after much reading the forum then maybe im right in suggesting a new alternator.
The cars rev counter will cut out every now and then under like a constant power, also with the whine noise. I think its this as the car cuts out when the rev needle drops off the scale and i need to blip it to get the counter to respond again.
ALternator the case?
  Astra 1.9Cdti SRi
The Rev count works on a vaccum so sucking air in, notice you have ITB's so this will be different, so im not sure on that..
Have you test that theres circa 12v+ coming from the alternator? you will need a multimeter to test,
