Are Clio Mk1 and R5 subframes the same?
GasManLS7
  Clio 182
As per the title, are Clio Mk1 and R5 subframes the same? I'm looking to use one to make a jig to make a tubular maxi subframe and push the lower arms out by 50mm each side. I've already swapped in 182 cup lower arms etc so need to get a spare subframe with all the same mounting points as a Mk1 Valver subframe.
Brigsy
  T.Turbo
They are similar but have differences from memory. I recall the clio has a bush on one subframe mounting point and the rad mounts are different.
Brigsy
  T.Turbo
If the mounting points match then you would be better off without the bush. Valver/williams have the bush on o/s rear subframe mounting point for some reason.
