Im with chip on that.
If it is restrictive (which i doubt it would be any down grade on the standard inlet) it surely shouldnt make much difference? Plus its easier maintenance wise
Its not if the inlet as a whole is restrictive that is the issue, clearly it wont be, but the key thing is if it flows evenly on the four cylinders, as you dont want to end up with one cylinder leaner than the others as it will risk a meltdown. Where the furthest away cylinder is tapered around, if thats not done at a suitable angle it will potentially cause those sort of issues.
Probably be ok, but like I said, no guarentees.
Your knowledge is much more technical than mine.
I've been doing all this stuff a lot longer than most folk on here, its just a side effect of being an old git, plus of course being a saddo science geek helps, lol
Thats true. Have you never considered condensing both of your clios into one? and running the RS2 on the turbo car? I really want to see someone run it on a boosted application, would look so smart if it were to work!
Saying that i know both the clios serve different purposes so would be a bit pointless lol
Think ill just take the box off as it did fall down the side was resting on top but tried to prise it out slowly and fell :/
Never took a box off either so suppose its another learning curve for me..
Very interesting that chip, been doing abit of reading on inlet manifolds etc and theres alot more to it than meets the eye.
Dan does that fit with out cutting the bulk head? looks as if it will be tight!
so its simply a few bolts then taking box off? ill have a look on here for any guides tips ect
As above, be very careful. Once the box is wiggled back on the first thing i do is put a bellhousing bolt in and put the clutch cable on to make sure it feels OK.
Would be a right c**t to put the whole car back together only to find the release bearing has fallen off the fork!!
I remember years ago putting a box back on my mk1 without the arm in there, as im used to working on cars with proper gearboxes where you dont have to balance a release arm in them as you put it back together, lol
Its a mistake you only make once, lol
Haha i bet people could hear you swearing for miles around lol! if i did that id certainly kick my car and walk off in a rageing fit!
So basically i can fit it exaclty how it is in that picture.
do you run one on yours chip need to have a proper good read through your thread
That allowed me to use it at silverstone despite the fact that the engine was breathing over a litre in 5 minutes of use on track.
Think I would have thrown the towel at that one so hats off to you sir.
i thought the carbon canistor bit was to the far left side of the engine?
Got lobbed off at bedford for dropping oil, and had silverstone 2 days later, so knocked it up in the hilton car park from bits from a scrapyard and bits borrowed off the mrs car (her mocal catch tank) and some fittings from B&Q, was damned if I was going to miss 2 trackdays in one weekend!
