Clio 172
				G'day all,
My 172 clutch is at 200,000km, and starting to show signs of dying. You can depress the clutch fully and the clutch is still slightly engaged, and if you have it in first, it will start creeping forward, and reverse is impossible to get into without turning the car off and back on! It's on the original cable and adjuster to my knowledge too, however putting a few washers on the cable hasn't seemed to improve it at all, so that's what makes me think it's the clutch (unless someone has other advice? It's very heavy too.)
I'm also from Australia, so parts are hard to come by, or have pretty lengthy wait times, so going to try and order everything in one go, however I have some questions
1. Is it a particularly hard job? I mean probably is, the most I've ever delved into drivetrain stuff is replacing the diff on an MX5, shadowed a friend taking his engine out of his Subaru, and the offside shaft of my 172. Granted I imagine it will be off the road for a few days minimum?
2. Is the flywheel for these single or dual mass? And if the former, is it worth getting machined? And if so, can you reuse the flywheel bolts or are they torque-to-yield?
3. What's the general break in period for the clutches on these? 500ish km of around town driving I imagine?
4. Is it worth dropping the subframe completely or is it possible to just get away with leaning it on one side?
And 5, what's the best way of aligning the clutch to the input shaft? I've read there is no clutch alignment tool available for these!
Cheers for anyone that read this far😅 hope you guys can be of great help!
