Fiesta ST-3
Basically when doing my engine conversion we have finally got round to fitting the auxillary belt, the only problem is its too tight. So we changed the air con pump from my coupe one to a clio one and that was much smaller so that helped. But the belt is still too tight. When i went to my local motor factors i gave the reg of a phase 2 engine and my engine is a phase 1. Is there any diffrence in the length of the belts or maybe the cam pully has a larger diameter on each engine? Heres a picture of the code on the belt i have, not sure if it helps in anyway
