Backup Script
Wrote a vbscript to backup folders and files. Just thought I would share it. Cut and paste to notpad and save it as backup.vbs and edit the variables backUpDrive, backUpLocation and toBeBackedUpArray to what ever you want.
It will take a fair while the first time you run it especialy if you have a lot of files. After the first run it only replaces files that have been modified so will run quite quickly.
Use at your own risk. No resposability accepted if it goes tits up!
Code:
' VBScript that backs up files. Replaces files that have been modified.
Option Explicit
Dim backUpLocation
Dim backUpDrive
' Set the location of the backup device and folder
backUpDrive = "D:"
backUpLocation = "\backup"
Dim toBeBackedUpArray
Dim arraySize
Dim loopCounter
' Array of folders to be backed up
toBeBackedUpArray = Array("C:\Documents and Settings\Dave\My Documents", "C:\Documents and Settings\Laura\My Documents")
' Get the array size
arraySize = UBound(toBeBackedUpArray)
' Initialise the loop counter
loopCounter = 0
Dim oFSO
Dim file
Dim oFileA
Dim oFileB
Dim destinationFile
Dim originalFolder
Dim destinationFolder
Dim currentDirectoryForBackup
Dim date1, date2
' Create the file system object used to copy the files
Set oFSO = CreateObject("Scripting.FileSystemObject")
Dim objShell
Set objShell = CreateObject("Wscript.Shell")
Dim noOfFilesBackedUpNew
Dim noOfFilesUpdated
noOfFilesBackedUpNew = 0
noOfFilesUpdated = 0
' If the root folder does not exist then create it.
If Not oFSO.FolderExists(backUpLocation) Then
  objShell.Run("cmd /c mkdir """ & backUpDrive & backUpLocation &""""), 0, TRUE
End if
'Loop through the locations to be backed up.
While loopCounter <=  arraySize
        currentDirectoryForBackup = toBeBackedUpArray(loopCounter)
        destinationFolder = backUpDrive & backUpLocation & Mid(currentDirectoryForBackup, 3, len(currentDirectoryForBackup))
        'WScript.Echo destinationFolder
	If Not oFSO.FolderExists(destinationFolder) Then
          objShell.Run("cmd /c mkdir """ & destinationFolder &""""), 0, TRUE
        End if
        ' Create/replace files in the root dir for backup
    	For Each file In oFSO.GetFolder(currentDirectoryForBackup).Files
           CreateReplaceFiles(file)
        Next
        ' Creates folders that don't already exist
        For Each originalFolder In oFSO.GetFolder(currentDirectoryForBackup).SubFolders
           CreateFolders(originalFolder)
        Next
        ' Incrament the loop counter
        loopCounter = loopCounter + 1
Wend
WScript.Echo "Done " & noOfFilesBackedUpNew & " new files backed up. " & noOfFilesUpdated & " modified files replaced."
' Recursive subroutine creates folders that don't already exist.
Sub CreateFolders(originalFolder)
   destinationFolder = backUpDrive & backUpLocation & Mid(originalFolder, 3, len(originalFolder))
   ' If the folder does not exist then create it.
      On Error Resume Next
      oFSO.CreateFolder(destinationFolder)
      If Err.Number <> 0 then
        WScript.Echo"Error Backingup folder " & originalFolder
      End If
      On Error Goto 0
   End if
   ' Create/replace files in each folder
   For Each file In oFSO.GetFolder(originalFolder).Files
   Next
   ' Recursive part of the subroutine to create subfolders.
   For Each originalFolder In oFSO.GetFolder(originalFolder).SubFolders
   Next
End Sub
' Subroutine to create or replace files
Sub CreateReplaceFiles(file)
 destinationFile = backUpDrive & backUpLocation & Mid(file, 3, len(file))
 'WScript.Echo destinationFile
  ' If the file does not exist then copy it.
  If Not oFSO.FileExists(destinationFile) Then
       oFSO.CopyFile file, destinationFile
         WScript.Echo "Error Backing up file " & file
       Else
         noOfFilesBackedUpNew = noOfFilesBackedUpNew+1
       End If
       On Error Goto 0
  Else
     Set oFileA = oFSO.GetFile(file)
     date1 = oFileA.DateLastModified
     Set oFileB = oFSO.GetFile(destinationFile)
     date2 = oFileB.DateLastModified
     ' If the file is newer then overwrite the backed up file
     If DateDiff("s",date2,date1) > 0 then
       oFSO.CopyFile file, destinationFile, true
       Else
         noOfFilesUpdated = noOfFilesUpdated+1
       End If
       On Error Goto 0
     End if
  End if
End Sub
'CleanUp
Set backUpLocation = Nothing
Set backUpDrive = Nothing
Set toBeBackedUpArray = Nothing
Set arraySize = Nothing
Set loopCounter= Nothing
Set oFSO = Nothing
Set file = Nothing
Set oFileA = Nothing
Set oFileB = Nothing
Set destinationFile = Nothing
Set originalFolder = Nothing
Set destinationFolder = Nothing
Set date1 = Nothing
Set date2 = Nothing
Set objShell = Nothing
Set noOfFilesBackedUpNew = Nothing
Set noOfFilesUpdated = Nothing
I'm sure some windows people will find this useful!
Why a time & date check rather than using the archive flag for it's intended use?
