Battery drain issue when stood, but not obvious!! Other traders look inside! :)
Car  Mondeo TDCI 130
Hello,
Right, got 2 x 182's with the same problem, if stood for 4-5 day's the battery's are dead. Had the meter on them, discharge 0.16 so thats sod all.
Anyone got any idea's? both battery's are new, so that aint the issue, all charging ok, and nothing obvious.
Anyone had the same problem? i was wondering maybe alternator, but the drain doesn't seem enough, for an example i tried another clio, and that was reading the same!
Cheers chaps!
0.16 amps? If it is then that's excessive. Should be below 0.06 amps. Are you checking the current draw on the negative side of the battery?
