Bedding/running in cams and flowed head
Car  182 Trophy
I'll very shortly be fitting a flowed/ported head, matched inlets and Catcams 438s to my 182.
I've not found any definitive guides to bedding in the cams themselves (20mins at 2-3k rpm has been suggested, to avoid the higher wear potential at idle) and also to 'running in' the newly machined head to remove any fines/residues etc.
Does anyone have any advice on this?
Sent from my iPad using Tapatalk
The other suggestion I've had is to do a second oils change after 20-30 miles, which seems reasonable/sensible.
got to admit i've never really bothered with the whole running cams in. will keep a high idle for few minutes though.
If you don't mind me asking, who did your head mate?
Max @MS Custom Engineering in Frome, Somerset. He's the chap that does the matched inlets etc.
Parts arrived back with me yesterday and being installed next weekend.
I thought that heads were supposed to be spotlessly clean after work, to make sure there's no risk of engine damage?
Absolutely! Which is why all of the parts are still packaged up and sealed in the box. They were cleaned before being delivered.
