Re: James/BigAsh 182 Race Car by TDF... It doesn't get much better than this! *Pic He
I think mine were a bit of a trial run and they turned out really well but were only possible by removing the slam-panel - and the a/c kit and bonnet catch which I'd already done. Matt re-mounted the radiator and its pretty much out of the way but he's going to fit a smaller VW Polo radiator which will get it right out of the way of the flow to the throttles.
Having seen your car in its infancy I'd really like to see your car in the metal now its finished but I live a bit too far away to just to pop up, I'll be at TDF Saturday 4th in the morning to drop my car off though if you and/or the car are around?
I think Matt mentioned that around 210/215 was about as far as the standard injectors will flow, above that needs the larger injectors from the Megane 225.
I can remember the jump up in power after having had the ITBs fitted, was probably around 170 before that but after it felt like 270. It still feels like TOO MUCH power on the road but on the track I've got used to it now, 220 sounds about right though!!!!
(Oh, I meant - you should definitely fit some heat shielding. Matt fitted some Nimbus to mine and seems like it’s done the trick)
Yes they have worked out really well Mark and I'm really happy with the power it's made, the Polo rad is a really good option from the pictures I have seen of them fitted it does look to create a good amount of space.
The car will be definitely be there but I'm away skiing for the week so I'm not around unfortunately! I'm sure Matt will take you for a spin in it if you wanted as I have said he is more than welcome to use it as a promo/ test car whenever he likes
(It doesn't like driving on the roads though
Yes that is what we discussed the other day and megane injectors are the way forward, I wasn't expecting the clio could handle anymore power than it has got but it manages it so well that in the long term there is potential with the car to handle a fair bit more power but that will be a few years down the line for me
Ahhh sorry, Yes well we have a small piece of nimbus and Matt did say we are going to fit some more heat shield between now and Donington
The Megane injectors aren't all that expensive now either, my standard ones with 428s and 90mm jenveys are at 99% duty on full chat.
Yes I think on the dyno at one stage mine were at 100% so we have lifted away from that a little to keep it running safe
