BMC CDA, Which One?
I have one on the focus... Just had to measure the pipe coming from the engine to the airbox.
That says outer diameter so you'd have to measure the inside of the pipe.
You can get reducers and other bits for them aswell if those sizes above are to small/big
Seems as though they're selling everything you need to fit it with it. 2 reducers (one 60mm and one 65mm).
Think all you'd need is a breather filter??
First one is the one for you and youll need a Reduer....Ive got one in the house but depends on what size your throttle body is
Lol i've got plastic reducers on mine as theyre the only ones in the size i needed.... They're not that bad tbh and only £2.50
The noise the BMC throws out is good love it on mine, Gary you know where i live if you wanna hear it :rasp:
As for performance ill tell you once i get the car RR again in september
just get a pipercross filter or get the one that k-tec are doing the sale on :P
Saw the ones K-Tec were selling, open kit though though so that's ano-no, noise with a bit of power increase I should have said :p
First one it is then, will check the connections the now.
if the bodys 64mm then ive got a reducer thatll fit...sayin that youll need a 90 bend not a reducer
You'll need an adapter plate to fit one to an earlier D4F as there isn't a normal throttle body that you can bang it on.
