Brake bleeding q's..
  1.8 Civic EX
So I'm getting my new discs and pads fitted this week. (Brembo HC's and EBC greenstuff for those that may be intereted). Is it worth bleeding the brakes too? (done around 27k miles now and to my knowledge it's not been done in the past) Any hints and tips for doing so? I know not to let it run out of fluid otherwise I'll be getting air bubbles but anything else I should know about? I've got a FF so that means ABS. Does that make any difference when it comes bleeding?
cheers peeps!
  RS Clio 200
should be able to get away with it... just make sure the reservoir cap is off when you prise open the caliper.
on the other hand, its never a bad thing to have a change of fluid
Jamie
  Audi B8.5 RS4 & 200
If your brakes are spongy bleed them, if not there is no point. Having ABS makes no odds to bleeding them.
