Brake Caliper Problem
santoz
Car  Clio 182
Long story short;
Replaced brake pads and disks with new EBC Blue NDX Pads and HC Brembos on the front and new Brake Fluid. Followed proper bedding in procedure but noticed that brakes were 'sticking', upon further inspection noticed a hole in the rubber boot of my right caliper and a bit of dirt / rust on the piston.
Proceded to strip caliper down to clean it, but what I need to know is there a kit to replace the rubber boot and o-ring seal and roughly how much?
Also any other tips when rebuilding the caliper?
Cheers!
biggred calipers mate, about £25 I think for set of seals for both sides.
make sure that the dirt & grit hasn't damaged the caliper or piston mate, otherwise you'll need to replace.
