Brake Changing Guide for a Cup
Car  172 Cup SOLD
Got new disc's, lines and pads due to be delivered very shortly, how easy are they all to change?
Is there a guide somewhere?
I've found the front pad changing guide but not disc or lines
Is it a fairly easy task?
yea, discs are easy, use your common sense and a large hammer to get the old ones off
brake lines are easy (but messy) bleeding the system is the tricky part
if you can do pads you can do disks to.
simply remove the caliper completely (instead of undoing just 1 bolt and pivoting the caliper while changing the pads remove it completely just undo the othe bolt as well)
youll need a torx set to remove the 2 screws the secure the disk then as fred said just hammer it off, i know very little about cars but changed the disks easily
How much would you expect to pay to have discs/pads/lines done? I'm trying to work out if it's worth my while fiddling with a car in this cold weather.
