brakes Whirring
  www.renparts.co.uk
My brakes are making a whirring noise when you are nearly stopped. Seems to be the front. Thought it was worn out discs so replaced those and it continues, replaced pads a couple of months ago also. Im at a loss, have a cooked the pads rendering them useless?
thanks
josh
  Renault Clio1.2Versailles
lol with it being warmer atm, the temperature in the air and of the sun dries the oil and brake fluid making them squeak when you come to stop or pull up, and with it being dry, dust and dirt sticks to them more easily, which also makes the brakes squeal!!
  www.renparts.co.uk
frauds discs. and standard before that. i changed discs becuase i thought this was what was causing it as the old ones were a lil bit worn. ill try replacing the pads again.
