brakes
yes should be ok. check with k-tec first though. all the abs does is moniter wheel speed and release the brakes if the wheel is about to lock and then reaplies the brakes again so unless the abs teeth are on the discs and the new discs dont have them there wont be a problem.
it should have ABS rings on the DS. The kit should work with the valver calipers as the spacing is the same.
is your car really pushing that much power over standard to need bigger brakes tho?
just a thought, i can think of better ways to spend £200!
