broken dip stick holder
The sheath the dip stick slides into has snapped off at the block.
Can I get it out without removing the sump? There is nothing proud of the block.
I assume I can get a new one from Renault?
I have an engine lying about I will look later to see of it can be removed. If so I have a spare one if need be ...
This happened to me, we had to use something that turns the wrong way then it draws it out? Forget the name now?
I have 2 spare engines lol. I also have pic that seems to show I could get it out from inside no probs.
I have some of those (can't remember the name either lol) I'll give it a go. Thanks.
You need a reverse thread extractor. Screw it in and pull the mofo out.
​Shouldnt be to hard only a little o'ring holding it in
