broken dip stick holder
  FF Clio 182
The sheath the dip stick slides into has snapped off at the block.
Can I get it out without removing the sump? There is nothing proud of the block.
I assume I can get a new one from Renault?
I have an engine lying about I will look later to see of it can be removed. If so I have a spare one if need be ...
  182, SQ7, Trafic
This happened to me, we had to use something that turns the wrong way then it draws it out? Forget the name now?
I have 2 spare engines lol. I also have pic that seems to show I could get it out from inside no probs.
I have some of those (can't remember the name either lol) I'll give it a go. Thanks.
Dr HMS Derv Destroyer
  MK1DCi/vivaro/REN’11
You need a reverse thread extractor. Screw it in and pull the mofo out.
​Shouldnt be to hard only a little o'ring holding it in
