car wont fire
Car  172 y reg flamer
just had the front bumper off to fix my xenon, sorted that fine. puts it all back together and now the car wont start!
only unplugged the one headlight and the fogs.
its not the immobiliser as the light goes off when i turn the key
car turns but wont fire and there is a loud whine from the coil pack
any ideas
Re: car wont fire EDIT : car just started
took the front end and the iffy headlight off to have a look around, still nothing.
puts everthing back together and car started firts time:mad:
headlight came on and wouldn't go off, stopped the car then started agin and its fine now:mad:
FRENCH!
try taking the top off the air filter box if you have the standard one on it and spray easy start or brake cleaner in to the engine wile some one is turning your car over and if that does not work check all earth leads
