Car wont start!!! Imobilser>??? clio 172
Car  Clio 172 + 4 others!
My 02 plate clio 172 just will not start
Im sure its the imobiliser!!
I unlock the car and the light is still flashing (red round one on dash)
When i try and start the car, the red round light stays on..
it turns over 2 times and cuts out....
any ideas????:dead:
its not recognising the key, you got another key? try that, if thats no use then the aerial round the ignition barrels probably duff
should flash, then key in and turned shoudl stay on solid for a second or to.
if it flashes then its not recognised the key.
Chris is spot on, the light only goes out when the reader confirms the correct key is in the ignition. Try your spare key. then if that doesnt work call your dealer and drop your pants.
yup these guys are right if its trying to start then stopping and you have the red light on try spare if not its the aerial, i had this problem when i converted my car key wasnt coded to uch and it wudnt turn over didnt get mine sorted at renault but if its just the aerial they should be able to sort it
The light stays on solid when i put the key in even, doesnt flash or go out
ok its deffo not key or pickup ring, as i just tried all that and the light flashes like mad!
The light just stays on solid!
engine fault maybe???
