Cheap 182 TB's Project.
Tom
  i3
Following on from my/our 205 R1 build (which almost works)
Ive decided to (slowly) work on trying to fit a similar system to the 182.
Ive got hold of these
For not alot (£75 thats not the actual ones in the pic.)
All i need to do now is get an ecu and a manifold made up.
I will keep you updated as i go, just need to to a bit more research.
  Milltek'd 182
looks very involved (and hard)!! but good luck mate, should be pretty rewarding if you do it yourself....not to mention having a bloody fast car ;)
  FOR SALE!!!
im intrested in doing this to as my mates dad does all metal work so could get the manifold made up easy were did u get the itb's from are they off a bike mate
  Lionel Richie
yeah they'd work, we did it to my mates rover k-series 1400 engine (ran on the std ecu too!!)
not as good as Jenvey's etc, but a hell of alot cheaper!
get an inlet manifold gasket as a template and then get a copy of that machined/lasercut out of ali and then weld some tubes on, couple of bits of silicone pipe and off you go
  FOR SALE!!!
is that all u need a template of ya gasket it cut out then the tubes and sum hose? thinkingbout doing this 2 my 1.2 8v as will be a good mode for around the 300 mark
  FOR SALE!!!
so what would i need then fred how much would u charge for doing the plate our could chirs manda do it for me were he works? how would they join the the pedal etc and ya i no it pointless on a 1.2 buts im getting 4-2-1 man and cams so this will top it all off nicly
Waitey
  Alpina D3, AC Cobra
I had no idea boggbros are so well known. They are based in an old shed down the road from me.
  Milltek'd 182
i assume its not quite as easy as getting bike trumpets and a new inlet, ecu and away we go?! does look like a nice halfway point from the jenveys though as they are pricey!
  Tungy
Yeah I'm sure some problems would be met along the way. It has been done to a Vtec engine searching on google. And I'm sure others have done it. I'd be very interested in doing this if it works out.
Tom
  i3
Well thats what you do with jenvey.
So yes it is.
But dont get too excited, i only have one part sorted.
  Milltek'd 182
well surely, for yozza to quote about 2-3 weeks (from their website) and for circa £3000 there's got to be something hard involved?!? lol
fancy doing mine next tom? ;)
  Lionel Richie
depends how tidy you do the install, we chop about the front slam pannel so people can retain the OE bonnet release, the secondary ecu gets hidden away, tidy loom (hidden inside the original etc etc) all takes time
you can do all the work for a Jenvey conversion and get it up and running in a day, but we like to do things nicely to retain the factory look inside the engine bay, rather than having wires everywhere and expensive components installed in a rubbish way. also we like to sort the dash and pedal configurtion so there no lights on etc
  Milltek'd 182
wasnt doubting your work fred! just used it as an example of me thinking there was more to it!! ;)
  Lionel Richie
no no, no offense taken, i was just trying to highlight what a proper install envolves
you can bodge it together in a day
M
mini-valver
I had a 1.3 Nova engine that had blown a rod out of the block that was running R1 carbs on a bogg bro's manifold! Sold the carbs etc to a mate but he never fitted them....
Can you not convert the F4R etc to carb or does the ECU run more things than fuelling and timing etc? Be even cheaper that way!
