Checking oil...
  182>FRS>VX220 now 350Z
Whats the correct procedure, is it ok to check when the car has been standing cold for some time? My dad reakons youre meant to run the engine for a bit then check? Obviously the car has to be on a level surface :p cheers
  clio 182 black /gold
You should check when cold 1, So you don,t burn yourself 2, So you know all the oil has settled and a truer reading is found.
Righto so basically the reading is meant to be taken when the oil is all in the sump...makes sense i guess
