Clio 1.6 16v coilpack help ? Engine running rough
Car  182 Trophy
Hi Guys
Engine on the 1.6 Clio is running a bit rough, does not like low revs but feels like its mis firing. Is the coil pack on these things the likely culprit ? I just called Euro car parts and they have said it does not have a coil pack but seperate coils ??
Can someone explain this to me as I’m a little confused
Sam
I have the 1.4 and it has 4 separate coils and it will probably only be one coil that has gone, but it is best to get them repaired in pairs as they normally go in quick secession of each other.
Thanks mate got my head around it now, plugged my mates diag into it and its showing cylinder 3 so going to replace that
change your sparkplugs too, and use a little white grease on the coil to plug connection. Worn plugs and bad connections put extra load on the coils
