Clio 172 high pressure power steering pipe
Car  clio 172
Looks like the leak is coming from the joint to the rubber hose as I can see the fluid at the joint.
ive seen on here people getting replacement pipe from a place called pirtek ? Anyone know how much they charge and where are they based ?
im in wrexham and work over in widnes.
Engine is currently out so hopefully won't be too hard to remove ?
Tony your a gem, i take it if i remove the hose and take it down they will be able to replace it.
Just need to have a look today how you remove it.
any ideas ?
thanks
mike
