Clio 172 low pressure turbo conversion help.
Car  172 turbo 'cup'
Currently fitting a conversion to a 172 cup and have become stuck!
Does anyone know where the turbo oil drain connects to the engine block? The oil return pipe does not seem to be long enough. Got no insturctions from K-tec and need it fished today!
You need to take the sump off and tap a 3/4bsp hole in the back of it, it needs to be on the flat part of the sump between the strengthening ribs.
Hope this helps.
cheers do you know if you need a boost solonoid or does the ecu and the map sensor control the boost as i said no instrutions and parts missing having a nightmare
Thats what i thought i think im just going to have to wait and speak to
k-tec tomrrow Thanks
Mate any more problems and I'll be more than happy to give you a hand, I only live in sunderland and have a bit of first hand experience with turbo clios. :)
Steve
Steve
Thanks for the offer mate. It's nearly completed now but I might have a few questions at a later date. :D
Cheers again.
One thing i would recommend is plumbing in some water cooling, garrett don't install there turbos with water jackets for no reason.
Thanks mate. It's already been sorted for water cooling. You would think it was supplied in the kit for the price!
