Clio 172 rear disc change
  RenaultSport clio 172 mk2
Please can anyone tell me how to remove the rear discs from a 172 - I had a quick look and there is a large circlip but was not sure whether that was holding the disc on or whether it was something to do with the wheel bearing.
Tks Greg
  Lionel Richie
the circlip is for the wheel bearing
remove the massive centre nut (32mm from memory)
and the thing should just pull off
  Lionel Richie
remove discs, take down to local garage, get them to press out old ones, press in new ones
or just buy the complete new discs and bearings ready assembled
Tks for info on discs, does anyone know what torque for the nuts when you put them back on?
Greg
  Ford Racing Puma
Sorry to post hijack, but I need to replace the rear brakes for the 182...
Was thinking performance rears to match the fronts. Ktec have a kit which is £200 delivered. Looking at the EBC disks and bearings in isolation they're much cheaper.
May be being thick, but about the ABS sensor ring ? Do the discs come with these?
Same brakes on the 182 and 172.
No need to upgrade the back they don't do anything anyway.
Stock disk are £140 I think and pads £40.
Not an issue the rings on the hub bit from memory only the Mk1's who have ABS rings
  2015 Audi S3 Stage 3
can the rear beam of a 172 with disc's be easily fitted onto the likes of a dci??
Bump..
I'm needing to chanhe my wheel bearings on the rear, I'm just wondering though.
As above, is it just the one big nut holding the whole disk/bearing on? I've got a whole new kit ready pressed top go on. Is it just a case of pulling it off and putting the new one on?
Thanks.
Djw John
Scotland - South
Wooft, good searching skills! Yeah, obviously the caliper has to be out the way but yes its just the large centre nut which iirc is actually 30mm, whip that off, tale the old disc off, put new disc on, put nut on FT
Thanks for the replies boys.
Can you tell me what size the hub nut is? 30 or 32mm?
All I should need then really is a socket set aye?
Thanks!
Also, is the hub nut a left hand thread?
Djw John
Scotland - South
I'm sure it's a 30mm but it takes seconds to check once the wheel is off. As for the thread, no I dont remember it being left handed. The hub nuts are nylocks and they are on properly tight so not an issue
Matt Cup
  Leon Cupra, 172 Cup
Make sure you replace/retain the deflector washers which is sandwiched between the bearing and stub axle when changing the discs, it also goes on a certain direction (can't remember which way it goes now).
  225 Cup & Williams
The hub nut that holds the rear disc on has to be tightened back up upon refitting with a torque wrench. 175nm is the torque setting you would set the wrench to.
Another thing, can you give me some infornmation on the ABS rings? Are they fitted to the disk itself or what?
The disks I've ordered say they are already fitted.
  HBT 172 Cup
I had to belt the s**t out of my old discs with a huge hammer to get them off! so if they dont just pull off, grab your hammer!
They are mintex discs and pads with the bearings and abs rings already fitted and pressed tony. Just for normal road use so mintex should be fine, so I've read!
Some good advice, thanks Laine! Haha
Matt Cup
  Leon Cupra, 172 Cup
Ol’ Tarby
  Clio 220 Trophy
Is the 100% as I'm about to buy the part
Yes. 30mm for the hub bolts. 17mm for the pad carrier. 175nm for the hub nut, 100nm for carrier bolts
Oh and don't forget to replace the spacer behind the disc in the same way it came off
chris blue
  clio Sport 197
Realise its on old thread
Anyone know the teeth on the ABS rear ring- ive seen both 44 and 48?
Any links for cheap rear discs, with bearings and ABS rings for a Phase 1?
Eurocarparts seem bleeding pricey on this item......
