CLIO 182 AIRBAG PROBLEM PLEASE HELP!
  clio182
Hi i have had my clio 182 on a diagnostics machine and i have had 6 fault codes, please someone help me to fix this as my mot is coming up ,
b107f air bag control unit locked following impact. new ecu or specialist ecu reset ?
b1042 voltage supply to low . fix all open circuits ?
b1031 drivers seat sensor open circuit . ?????
b1013 passenger front buckle ignitor open circuit . pretensioner?
b100b ignition circuit drivers side front open circuit . airbag or clock spring?
b1012 drivers side buckle retractor ignitor open circuit . pretensioner?
ANY HELP WOULD BE APPRECIATED MANY THANKS
  clio182
thanks for the warm welcome but i dont have much money and i just need to know what i need to do to fix the problem as i can get a friend to fix the problems
  Lionel Richie
sorry Wendy, but if your friend can fix the problem then why do they need to know how to fix it?
airbag ecu needs unlocking, the rest is just wiggling wires
  clio182
he only just finished college as a mechanic so not much experience, we just need to know what each code means e.g b1031 drivers seat sensor open circuit??? thanks
  clio182
the airbag light has now gone off, used resistors to trick the airbags etc and sent off ecu to clear crash codes ,
