RenaultSport Clio182
Hi guys,
I've seen plenty of posts of people asking for advice and what the fault could be (and I might get the same answer and/or advice) but I will give it a try. I've got a Clio 182 since the end of November 2013 and I use it mainly for commuting. I have always been quite thorough with the engine (warming it up, not pushing it until it is at working temperature and letting it cool down for a minute before stopping the engine even if I haven't pushed it).
I'll make an introduction, so I make sure I don't leave anything behind... Bought the car with 78.500 miles and as soon as I had it, I serviced the car (mainly I did an oil change - Elf Evolution SXR 5W-40, air, oil and cabin filters and spark plugs - GK PFR6E-10).
Had a major service at K-TEC before Christmas (79.196 miles) which included cam belt and aux belt with their kits, VVT pulley and water pump, which were due to.
Now with 80.800 miles the engine has started rattling (I didn't really notice until I was told by the guys at work while parking the car, maybe because of the after-market exhaust) but I have started to pay attention to it and I am worried about. The engine delivers the power and it runs smooth, however, the noise is there. I have to say that I haven't got any lights on in the dashboard, at least until now.
It has been parked for two weeks without being used, and I can't really tell if the noise has increased since then or has started suddenly...
Here you have a couple of videos, the first one with the engine idling and moving the phone around trying to find where is noisiest. And a second one, which I don't know if it is totally normal or not, is that noise coming from the coil pack when turning the ignition on.
I have seen that most of the faults are because of the Dephaser pulley/VVT, but it would be quite disappointing if it is - considering that has been fitted by a specialist and has done less than 2000 miles...
I'm thinking of checking tomorrow the spark plugs, but at the same time seems quite silly if there are no warning lights, the engine doesn't have a lumpy idle and runs fine...
I'm open to any questions, and thanks in advance for your time and attention.
David
David
