Clio 182 manifold to cat fitting kit?
Car  Black 182 FF
As in the title -is there such a thing?
One of the washer type things has corroded on mine, leaving the bolt slack and the spring under no tension. I've cut it out and put a normal bolt in for now, but can anyone tell me where I can get one of these (other than Renault)?
Hmm, it's not adding to cart and mentioning my browser isn't set to accept cookies when it is, guess I'll just have to phone and order tomorrow.
it wont be the washer/springs/bolts at fault, the gasket will be worn out
If you look at the kit, then there's a kind of washer/thing that the bolts sits in - that has actually rotten away on the passenger side and the bolt has fell in because the bolt head isn't big enough without the washer. Obviously the gasket will now need changing, but it's not the actual fault.
