I've enjoyed reading this so far. Fair play to all the work you've done up to date in such a short time :smile:
The silver Clio based on this thread is my other halves car.
I have an FRP and a shitty Civic run around, I would get rid of the Civic and have a 172 Cup instead. Well thats the thinking.
Just having a look, few available for reasonable money.
Joys of the internet:
FRONT ARCH LINERS
Trim Clip Wing Housing - 7703077435 x 10
Bolt MT Balck Washer – 7703017090 x 10
FRONT BUMPER
ECROU TOLL ¼ AC - 7703046145 x 5
Plaquette Fix AIL – 8200715957 x 5
Screws & Bolts – 7703016567 x 5
Nut C2 – 7703046120 x 5
Metal Bolt TH EMB RDL M6 x 20 – 7703602282 x 10
UNDER TRAY
Clip Nut M6 – 7703046048 x 10
One Thread Speed Nut 4,2 - 7703046116 x 10
FLGD HEX HD SCR M6X100 – 7703002820 x 10
Where you get all these screws and stuff from in the end mate? Got a link?
I had rubbing on mine with hard corners. Standard alloys with 205 tyres.Here you go buddy:
http://www.ebay.co.uk/itm/231302142911?_trksid=p2059210.m2749.l2649&ssPageName=STRK:MEBIDX:IT
http://www.ebay.co.uk/itm/301096044...49&var=600209008654&ssPageName=STRK:MEBIDX:IT
By the way with the 16mm on the rears running standard 182 wheels and standard sized tyres if you have more than two people in the car it does rub slightly. Which is really annoying as I was told that no rubbing occurs, I will be fitting Turins to mine soon so I will be running a different setup as the off set of the wheels is different.
got a link for that rear reg LED light mate seeing as though the other one didnt fit properly?Post man loving the deliveries at the moment.
"Bloody hell you buy enough stuff online"
Delivery from Hong kong rear registration LED light and cheap applicators (£1 a pack) also silver trek side repeaters
