Clio 182 - revving at 2.5-3k whilst turned on
Car  BG Clio 182
Recently when turning the ignition on the car has started revving like mad up to between 2.5-3k revs without touching anything. I was advised by a mate it was the throttle housing so we took the airbox out and gave the throttle housing a wash out with wd40 but it had no effect. Any other ideas to what the problem could be?
​cheers in advance
Most likely to be the inlet manifold. Remove and refit, cleaning all the mating surfaces/replace dead gaskets.
Cheers for your help with give this a go. If this isn't the case is there any sensors that could be causing this problem?
