BG FF 182
Started discussing this in someone else's thread so decided to start my own. Basically I want to turbo my 182 using a megane 225 turbo and manifold.
Main problems would be I need a custom inlet manifold and to adapt the breather to give the turbo clearance.
Few things I haven't researched so far.
First is if the oil feed and return for a 182 turbo kit would fit the megane turbo or could I use the meganes oil feed parts.
Second would the intercooler pipe work fit round the alternator and air con, not entirely sure how the 182 intercooler pipe work fits past either as it's very tight down there. Pictures would be good.
Third as it's going to be low pressure till I can afford to forge do I need a thicker head gasket as some kits have it and other don't and it's a lot of work if it's not needed.
Also if anyone else can think of any problems that might happen please post.
