Yarp
182 Turbo, E46 M3
Something can’t be assembled correctly. I personally can’t see the hub it’s self or hub flange being bent, more likely not pressed in square or fat enough so the disc is sitting to far forward. Could just be the Caliper or carrier not fit correctly tho.
If you get it apart, remove the disc and look behind the hub flange, you’ll soon see if the hub flange is sat correctly on/in the bearing.
I’ll take everything back off and check but was in the huff yesterday so gave up. That sounds like a possibility though
I never took the calliper bracket off and there’s zero tolerance in the bolt holes when the calliper attaches to the bracket so there’s no way it could be fitted incorrectly. If it’s on its fitted properly if that makes sense?
I've never bent a Clio hub doing bearings and I've done at least 20. I reckon they're a pair of pussies and haven't cleaned out the race seat in the hub or seated it correctly
Thats good to hear and makes me hopeful it’s not bent then. I hope he has been a pussy. I’m not telling him that though. I’m 6”2 and 16 stone and the lad who does it makes me look like a mincey little c**t. I’ll ask him nicely if he can ram it in harder
