Clio 197 Rear Discs and Pads Change Questions
Car  Clio 182 FF
Looking to change a 197s rear discs and pads and there doesn't seem to be any specific info on this. Is it similar/the same as the 182 with a bearing and ABS ring attached to the disc and a 30mm hub nut to 175nm? Is there also a shim like on the 182 which needs replacing?
I've contacted G172 about souring the parts so hopefully get this done soon!
Cheers guys
Similar set up @RichB yes mate
The genuine Renault rear discs I supply come complete with bearings pressed in and ABS rings attached (magnetic not toothed though like on your 182)
No shim/spacer/washer and a slightly bigger rear hub nut (which I have in aswel)
